Date/Time: Tue, 26 Nov 2024 08:38:29 +0000
Text
View Count: 187
[2023-12-13 15:04:49]
Pedro7 - Posts: 22
When using number bars calculated values i want for eg have Bid vol divided by ask vol and that value, using study divide, displayed as text preferably in the numberic table.
Is that possible ? I only find ways to display it as lines, bars...
Thx
[2023-12-13 16:48:56]
John - SC Support - Posts: 36286
There are ways to display the information as text, but there is not built-in way to display it within the Numbers Bars Calculated Values table itself.
To display the text in another region, set the "Draw Style" for the results subgraph to "Value of Subgraph" and set the "Width/Size" to a value that displays as you want (typically a value of around 10). Then shrink the scale value for that region until the numbers are in a single line.
It is possible to create a custom study that uses the table setup that is used for the Numbers Bars Calculated Values. Refer to the following for this:
ACSIL Interface Members - sc.Subgraph Array: Numeric Information Table Graph Draw Type
