Date/Time: Sun, 24 Nov 2024 20:57:34 +0000
paquete necesario para trading automatizado S3
View Count: 354
[2023-12-13 14:43:01] |
luciana - Posts: 24 |
Hola, compre el trading automatizado S3, querĂa saber si el paquete 3 es suficiente para utilizarlo en micro SP 500? Gracias |
[2023-12-13 16:41:43] |
I bought S3 automated trading, I wanted to know if package 3 is enough to use on micro SP 500?
In order to be able to connect to a trading service and/or get real-time data, you need to be on one of the "Integrated" packages. Refer to the information here: Description of Service Packages and Pricing: Integrated Packages Therefore, the lowest priced option would be Package 10. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2024-04-27 20:37:16] |
Tin43 - Posts: 90 |
Hola Luciana, te pedi solicitud para enviarte un privado.
