Date/Time: Tue, 26 Nov 2024 08:51:48 +0000
stock trading
View Count: 289
[2023-12-13 10:31:38] |
Dvora Klein - Posts: 1 |
hello is there an option to use market profile or foot print etc for stock trading? or its available only for futures trading if it is also for stocks how i conect and set it up thanks |
[2023-12-13 14:45:19] |
Sierra_Chart Engineering - Posts: 17179 |
Yes you can use Market Profile and Numbers Bars studies with the Sierra Chart US consolidated tape data: Denali Exchange Data Feed: US Equities Consolidated Tape Data Feed Notes You will want to use Service Package 11: Description of Service Packages and Pricing We have activated your Sierra Chart account for now. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
