Date/Time: Tue, 26 Nov 2024 08:22:23 +0000
[Programming Help] - Numbers Bars Text
View Count: 207
[2023-12-13 08:29:17] |
User884726 - Posts: 6 |
Good morning support board. I have a numbers bar chart that I want to display the Delta within the price lines, I have achieved this by setting the Column 1 Numbers Bar Text to 'Ask Vol Bid Vol Difference'. My question is, is there anyway that I can split the display to show 'Negative' numbers on the left and the 'Positive' numbers on the right, rather than in a single line. This separation would make easier viewing, I just can't seem to find anyway of doing this. It may be there is a way of just showing 'Negative' numbers in column 1 and 'Positive' numbers in column 2. I have attached a screen shot, maybe it will help in showing what I am trying to achieve. https://www.sierrachart.com/image.php?Image=1702455967354.png Thank you in advance for your time. Kind Regards Eddie |
[2023-12-13 16:08:17] |
John - SC Support - Posts: 36286 |
There is no support for doing what you are asking. But you can color the text based on +/- using one of the Text Coloring options. Refer to the following: Numbers Bars: Numbers Bars Text Coloring Methods For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
