Date/Time: Tue, 26 Nov 2024 08:47:49 +0000
Global setting to have all charts use the evening session.
View Count: 219
[2023-12-13 04:18:18] |
User472677 - Posts: 350 |
By default, I want all my charts to show evening session.i am not finding a global setting to do this.
[2023-12-13 16:04:46] |
John - SC Support - Posts: 36286 |
There is not a global setting for this. You would need to edit the Symbol Settings for the symbols you want to have this way and make sure they are setup to have the Evening Session enabled and that the start and end times for both the Day and Evening sessions are set the way you wan them. Refer to the following for instructions on how to edit the Symbol Settings: Global Symbol Settings: Instructions For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
