Date/Time: Tue, 26 Nov 2024 08:44:38 +0000
Question on re-downloading Data
View Count: 239
[2023-12-12 15:09:05]
A77 - Posts: 18
Activated now. By the way, to save you guys unnecessary downloads from me, can you quickly answer if I have to re-download all data every time we roll over?
I only want back-adjusted data but whenever there's a rollover the chart isn't correct anymore (at least on IQFeed), so all data had to be re-downloaded.
Unless there's a better way to adjust the charts for rollover (without re-downloading 10 years of tick data every time), please let me know.
[2023-12-12 16:36:04]
John - SC Support - Posts: 36286
We are not really understanding the issue here. You should not have any reason to re-download data unless you have a particular problem. But it should not occur every time you roll over. What exactly is happening when you roll over?
[2023-12-12 17:30:10]
A77 - Posts: 18
Nevermind. Just used to IQfeed's way of doing it where I had to re-download all their data every time there was a rollover.
For future reference/readers reading this post
Changing to a New Futures Contract Month: Changing to a New Futures Contract Month
Seems like the chart --> perform rollover does it automatically without you having to re-download years of tick data. If there is a problem, reload and re-calculate usually fixes it. If not, follow the steps in the link below.
Date Time Of Last Edit: 2023-12-12 17:31:06
[2023-12-13 14:38:57]
Sierra_Chart Engineering - Posts: 17179
Yes this is correct.
