Date/Time: Tue, 26 Nov 2024 08:48:19 +0000
21 EMA continuous - 5 min calc
View Count: 251
[2023-12-11 20:50:01] |
Jaydtrade - Posts: 87 |
How would I go about putting a 21 EMA close on a Renko chart but have the EMA calculation base of 5 min candles? Thanks!
[2023-12-11 21:46:39] |
John - SC Support - Posts: 36286 |
You have to choose one. Either the EMA is based on 5 minute candles or on the Renko. If you want it based on 5 minute candles, then you would need a 5 minute chart and put the EMA on it. Then you can use the Study/Price Overlay to overlay that EMA to the Renko chart. Refer to the following: Study/Price Overlay Study For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2023-12-11 23:25:38] |
Ah okay thank you!
