Date/Time: Tue, 26 Nov 2024 08:56:09 +0000
Unable to customize Control Bar after removing commands
View Count: 170
[2023-12-11 20:03:39] |
User264623 - Posts: 28 |
While customizing a Control Bar, I removed all of the 'Selected Control Bar Commands' and clicked "OK" before adding new ones. This control bar has now disappeared and now unable to right-click to customize the control bar to add commands, because it is no longer displayed on the screen. Not sure how get into the customize screen to add commands without it being visible?
[2023-12-11 21:44:07] |
John - SC Support - Posts: 36286 |
Select "Global Settings >> Customize Control Bars >> Control Bar #" where # is the number of the control bar you want to customize. Refer to the following: Control Bar: Customize Control Bars >> Control Bar 1-12 (Global Settings) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
