Date/Time: Tue, 26 Nov 2024 08:45:43 +0000
Copy chartbook to another instance
View Count: 725
[2023-12-11 19:13:08] |
User377189 - Posts: 172 |
I have two instances of sierra chart open on my PC I would like to move a chartbook from my main instance to the sub-instance, what is best way of doing this? |
[2023-12-11 21:26:53] |
John - SC Support - Posts: 36286 |
The best way is to simply copy the file. Make sure Sierra Chart is not running (in either instance) and then copy the chartbook file (with extension .cht) that is located in the Data folder under the main Sierra Chart installation to the Data folder under the sub-instance. The sub-instances are located under the main Sierra Chart installation folder and start with 'SierraChartInstance_', where after the underscore is a number that represents the sub-instance (the first sub-instance is number 2). For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
