Date/Time: Tue, 22 Apr 2025 07:30:37 +0000
trade orders window and trade position window not working
View Count: 341
[2023-12-11 14:59:40] |
Benz - Posts: 47 |
not able to bring up trade orders window and trade position window at all able to place and execute trades able to see orders on chart when placing just unable to bring up trade orders window and trade position window rolled contracts today - cant bring up on old dec 23 contracts or new mar 24 contracts Thank you support |
[2023-12-11 15:07:44] |
Sierra_Chart Engineering - Posts: 19295 |
Update Sierra Chart to the latest version: Software Download: Fast Update We do not understand this: rolled contracts today - cant bring up on old dec 23 contracts or new mar 24 contracts Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2023-12-11 15:08:18
[2023-12-11 15:14:24] |
Benz - Posts: 47 |
i was simply letting you know that trade orders window and trade position window are not working on old or new contracts. i was simply providing the only variable that i have changed. I have updated and that has solved problem thank you |
[2025-01-29 16:56:30] |
User237034: We have no idea what your issue is. If you have a Service Order ID, then that means an order exists, therefore why do you state you are Unable to execute trade orders? Also, this is not the correct thread to post this. You should open a new thread for your issue. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
