Date/Time: Tue, 26 Nov 2024 08:26:48 +0000
Manage Drawings not working on all charts
View Count: 237
[2023-12-11 14:52:03]
Technical - Posts: 158
I am on 2568.
After rollover, most of my charts roll & adjust as expected, however a few do not. They are TPO charts, if that matters. The difference is the "Manage Drawings" tool does not have the current contract in the "Symbols:" window. (See enclosure)
Typing the correct contract name in the "Symbols:" window has no effect.
I went into >chart settings>>Symbol and verified the contract, even re-added it. No difference.
I can rollover but I cannot adjust the drawings on a select number of charts.
image2023-12-11 08_36_12-Manage Drawings_ ESH24-CME_MESH24-CME [C.png / V - Attached On 2023-12-11 14:51:46 UTC - Size: 7.24 KB - 57 views
[2023-12-11 19:03:43]
John - SC Support - Posts: 36286
The pulldown in the top-right of that window does not change the symbol for the drawings, that just lets you select specific drawings based on the symbol they are associated with.
To change the symbol for a drawing, select the drawing in that window, and then select "Edit Symbol" and enter the symbol you want it to be associated with.
But, refer to the following regarding rolling over drawings:
Changing to a New Futures Contract Month: Allowing Lines and Other Chart Drawings From Other Contract Months to Appear on the Current Contract
