Date/Time: Mon, 25 Nov 2024 12:52:41 +0000
EUREX DATA
View Count: 367
[2023-12-11 12:04:32]
WhiteOG - Posts: 11
Hello, i have denali data feed and order teton with CME but i want to have EUREX too, can i have both with the denali data feed can someone check my account because i find it hard to find out myself because my english isnt my first language, and do i need to have any european brokerage account for EUREX or im good to go with IRONBEAM? Thanks in advance
[2023-12-11 18:55:41]
We have responded to the post you put at the following link:
Account Support Ticket
One extra note - the Teton Order Routing Service does not work with EUREX, so if you are wanting to trade EUREX from Sierra Chart, you will need to use a different order routing for EUREX.
We recommend having two trading accounts, one for the CME Group and one for EUREX, then setup two Sierra Chart installations, one for The CME Group and one for EUREX. Refer to the following:
Using Multiple Data and Trading Services at the Same Time: Step-By-Step Instructions to Install Multiple Copies of Sierra Chart
[2023-12-11 19:40:15]
WhiteOG - Posts: 11
What are other order routing options if teton doesn’t work, can you help me?
[2023-12-11 19:41:12]
WhiteOG - Posts: 11
And can i have the real data even if i dont have an trading account for eurex?
[2023-12-11 21:29:40]
Yes, you can get the real-time data without the need for a trading account for EUREX. This requirement of needing a trading account is only for the CME Group.
Either CQG or Rithmic. It depends on who your broker is as to whether they have these other order routing options available and whether they support trading EUREX.
[2024-03-01 04:41:02]
Jimmyy - Posts: 221
WhiteOG, Do you trade DAX futures ?
