Date/Time: Tue, 26 Nov 2024 08:43:56 +0000
UPGRADE PLAN
View Count: 197
[2023-12-11 10:58:40]
User313792 - Posts: 1
Hi i would like to buy the standard plan but i have a question, if i choose to integrate my broker and i want to switch the plan while using already one is possible? I mean can i do the upgrade with the difference or i have to wait the ending of the month?
[2023-12-11 18:26:44]
John - SC Support - Posts: 36286
You can change the Service Package you select at any time. When you do so, we do not charge or give a refund, rather we adjust your remaining Usage Time based on the difference in the package pricing. Therefore, if you change to a more expensive package, your remaining Usage Time will go down, and vice versa.
