Date/Time: Tue, 26 Nov 2024 08:41:45 +0000
Market by order is not working
View Count: 352
[2023-12-11 08:06:35]
Lilydo - Posts: 14
My account is service Package 12 and the data is CME with market depth for non-professional. I did follow the step to step instructions but on the DOM have not showed the market by order.
Please help me out.
[2023-12-11 17:11:32]
John - SC Support - Posts: 36286
Make sure you have followed all the instructions at the following link and that you have the correct columns displayed:
Market By Order Data: Step-by-Step Instructions
If you are still having an issue with this, then please get us an image of your chart by following these instructions:
[2023-12-11 18:25:52]
blt - Posts: 31
Hi SC Team
Tried to find solution for MBO problem on my own-did not work out
I think I went through all possible causes
Also I found many threads with similar posting-couldn't spot solution for the problem
Problem:
MBO showing "negative" values
MBO showing one column only (not set of orders)
As a brand new customer of SC your help would be appreciated a lot
Thank you
https://www.sierrachart.com/image.php?Image=1702318308382.png
[2023-12-11 19:51:05]
That is the wrong column. That is a "Pulling/Stacking" column. You need to add the "Bid Market Orders" and "Ask Market Orders" columns. Refer to the following:
Global Trade Settings Windows: Customize Chart/Trade DOM Columns (Chart Specific)
[2023-12-11 21:17:10]
blt - Posts: 31
To
John-SC Support
Working to perfection !!!
Ashamed and humiliated I am
Sorry for your time
Thank you again
