Date/Time: Mon, 14 Sep 2026 22:26:37 +0000
[User Discussion] - Compare range of individual values
View Count: 1133
[2023-12-11 00:27:12]
User273277 - Posts: 144
I want to find the first swing low in the most recent 100 bars that is above the current bar low. Something like this where it returns the first occurrence: L<ID1.SG2[0:-100]
But it looks like spreadsheets can not iterate over a range of values: Study/Chart Alerts And Scanning: Referencing A Range of Data
"... this is not valid: =SG1[0:-10] > 100 ... This requires an iteration which is not possible with Spreadsheet formulas."
The documenation page does not specify how this iteration would be done.
Any help would be appreciated.
[2023-12-11 17:00:51]
John - SC Support - Posts: 47889
Spreadsheets do not iterate, that is correct. But you can use the "EARLIESTNONZEROVALUE" to find the first instance of a Swing Low within a range of data. Refer to the following:
https://www.sierrachart.com/index.php?page=doc/SpreadsheetFunctions.html#EARLIESTNONZEROVALUE_Function
You would have to use multiple columns to get consecutive values to test against your condition, then have a column that gives you the answer you want.
[2023-12-12 04:13:40]
Thank you. That helped get the code most of the way there on the first try.
For the multiple columns, I have tried to see how to use things like vlookup, search, nmatch, but I don't see how any of these can select the x value in the swing low list.
Ie. it looks like I need to do something like =MOSTRECENTNONZEROVALUE(ID1.SG2@4:ID1.SG2@54,2) to select the second value in its own column.
Date Time Of Last Edit: 2023-12-12 04:15:42
[2023-12-12 06:07:58]
I found another post from a while ago with a similar question. There was no final solution posted.
I put into column P to remove the zeros: =IF(ID1.SG2@3=0,NOVALUE,ID1.SG2@3)
Then I am trying to use index in columns q-z for now to pull the next sequential non-novalue number: =INDEX(P4:P54,NMATCH(2,1,P4:P54,0),1)
But the index is not working. I haven't used index here before, and looking for working examples.
[2023-12-12 07:18:09]
I got index with nmatch to work with a static value.
It looks like nmatch requires a static value paramater and does not accept a cell reference?
ie.
=INDEX(O4:O54,NMATCH(1,4678.1875,P4:P54,0),1)
I need to do something like:
=INDEX(O4:O54,NMATCH(1,O4,P4:P54,0),1)
I need to enter a cell reference of O4 instead of the static 4678.1875.
Is there another way to do this?
Date Time Of Last Edit: 2023-12-12 07:20:12
