Date/Time: Tue, 26 Nov 2024 08:38:47 +0000
Scaling two separate numbers bars charts with one scale
View Count: 198
[2023-12-10 01:12:07] |
Ed Levy - Posts: 17 |
Hello, I have a 56 tick renko numbers bars chart and a one minute numbers bars chart. These charts are part of the same chart book and look at the same symbol. I'd like to be able to scale up and down on price levels as well as adjust the spacing between ticks for both charts with one scale. I'd also like to be able to see both charts at the same price instead of adjusting both of them independently as I go. Can you please advise? Thanks.
[2023-12-11 16:38:36] |
John - SC Support - Posts: 36286 |
It sounds like you want to link the charts and have the "Vertical Scale" option enabled between them. Refer to the following: Chart Settings: Linking For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
