Date/Time: Tue, 26 Nov 2024 08:35:09 +0000
chart calc
View Count: 208
[2023-12-09 18:28:17] |
User651547 - Posts: 59 |
Hi . how can i set in chart calc taht show the value in usd not only PD and PC
[2023-12-11 16:27:01] |
John - SC Support - Posts: 36286 |
In the Drawing Properties (or in the Configuration, depending on when you want to make the change) under Labels is the option for "Currency Value". Refer to the following: Chart Drawing Tools: Chart Calculator Configuration For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
