Date/Time: Tue, 26 Nov 2024 08:22:21 +0000
[User Discussion] - Using study drawing tools and adjust the BeginIndex on the X Axis or as offset
View Count: 227
[2023-12-09 15:09:29] |
User980182 - Posts: 3 |
Hello, i have searched through the support board for this could not find. Is there a way or has it been requested to be able to adjust (in pixels or otherwise) when drawing a marker DRAWING_MARKER in a study with s_UseTool - i would like to be able to adjust the marker to align to the edge of a candle on the left or the right or as some offset. Currently it only displays on the centre line at the Y price specified. A bit like the DrawStyle for subgraphs eg square offset left/right or square offset left/right candlestick thanks |
[2023-12-11 17:53:52] |
Can someone enlighten me as to what is the issue with this question. I pored over and over past posts documentation as we are required to do so. There is no clarity on how to achieve the above and was posted with idea if not already possible would be a feature request and a reasonable request to be supported. Why was this just labelled as programming help and just ignored. I have read the support process and many examples of where sierra support do not respond etc But to me this is a reasonable question thanks |
