Date/Time: Tue, 26 Nov 2024 08:34:21 +0000
Horizontal Ray and Extending Rectangle Tool Issue
View Count: 243
[2023-12-09 12:44:03] |
ANDREW CALDERWOOD - Posts: 2 |
Hi there. I am just wanting to check something regarding changing keyboard shortcuts for horizontal ray and extending rectangle for my market profiles... When i go to 'Sierra chart- Global settings -customize keyboard- Tools' etc...change to my preffered commands... I click 'assign' and 'OK' but it only seems to change it on the actual sierra chart but not the market profiles. They remain the original commands. Is this a technical issue with my platform? thanks... Andy |
[2023-12-09 19:33:06] |
Sierra_Chart Engineering - Posts: 17179 |
We do not understand this: but it only seems to change it on the actual sierra chart but not the market profiles.
If you are setting up a particular keyboard shortcut for a very specific command and use that keyboard shortcut it will then invoke that command. This is very simple and straightforward. It the keyboard shortcut does not work, it would mean that that the operating system is interfering with it in some way and that is outside of our control. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2023-12-09 19:33:24
