Date/Time: Wed, 27 Nov 2024 04:43:54 +0000
Candlestick patterns..
View Count: 1263
[2014-07-28 02:12:42] |
The Stealthy Trader - Posts: 185 |
Hi, so I'm exploring the Candlestick Patterns Finder and I've noticed some patterns show both UEN(Bullish Up Engulfing) & DEN(Bearish Down Engulfing) for the same candle.. From my understanding of Candlesticks, either the candle is bullish engulfing or bearish engulfing..not both. Please advise.. Thanks so much, Jonathan |
[2014-07-29 03:18:28] |
This is not within the scope of our support. The source code for the Candlestick Patterns Finder study can be found in the /ACS_Source folder. You can analyze the code and make any necessary changes to it. For information about making changes to it, refer to: https://www.sierrachart.com/index.php?page=doc/doc_BuildCustomStudiesDLL.html There must be something about the particular candlestick patterns that you are looking at which meets the condition of both. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
