Date/Time: Tue, 26 Nov 2024 08:34:33 +0000
Tool Value Window
View Count: 241
[2023-12-08 21:28:01]
User417302 - Posts: 67
After installing v.2568, the toll value window is not longer visible? I can however see the compact tool value window but not the one I need? How can I get it visible again? I have checked and it's not buried behind another window, it just disappeared.
Thanks,
[2023-12-08 21:40:15]
John - SC Support - Posts: 36286
Select "Chart >> Reset Child Windows". If the Tool Value Window is already set to display, then it should show up, otherwise toggle it off and then back on. Refer to the following:
Chart Menu: Reset Child Window (Chart menu)
If the above does not immediately solve this, then check the option for "Show/Hide Tool Values Window when tool Activated/Deactivated" as you may need to set the tool to Crosshairs and click in the chart to activate the window.
Chart Drawing Tools: Show/Hide Tool Values Window When Tool Activated/Deactivated (Tool Settings >> Chart Values >> Chart Values)
