Date/Time: Tue, 26 Nov 2024 08:24:55 +0000
Color Bar Based on Alert Condition Text with Background overlay to Region 1
View Count: 209
[2023-12-08 18:41:48] |
eminimom - Posts: 24 |
I have in Region 2 a Color Bar Based on Alert Condition that shows Text with Background for SG1 when the indicator has a crossover above a level (it is an oscillator). I want to Overlay that "Extreme" Subgraph Text with Background on to Price Region 1 at the same time it prints on the Region 2. I have tried using Study/Price Overlay, Study Subgraph Reference and any other means of accomplishing this but have not been successful. Here is what my Study in Region 2 looks like. What do you suggest? Thanks in advance
Private File |
[2023-12-08 19:26:21] |
John - SC Support - Posts: 36286 |
The issue is that when you use an overlay, or a reference, the location of that information is at the level as defined in region 2 (so somewhere about +/-40), so you will not be able to see this in your main chart. The only solution would be to use another "Color Bar Based on Alert Condition" study and set the alert to be the other Color Bar Based on Alert Condition study with Subgraph 1, so the Alert condition would be: =ID1.SG1 Where ID1 is the ID of the first Color Bar Based on Alert Condition that is in Region 2. Then set it up the same way, but make sure your "Output When Condition True" is going to place the information relative to the Main Price Graph. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
