Date/Time: Tue, 26 Nov 2024 08:58:45 +0000
Is there a way to copy toolbar layout from one installation of SC to another?
View Count: 258
[2023-12-08 17:20:28]
AmberNinja - Posts: 31
How do I save and copy my toolbar layout from one installation of SC to another or share it with a friend?
Is there a way to copy the whole layout/theme of SC to another install? Thanks
[2023-12-08 19:18:45]
John - SC Support - Posts: 36286
The information for what is contained in each Control Bar is stored in the Sierra4.config file located in the Main Sierra Chart Installation Folder. But, this also has all the other global settings for a setup, so you need to be sure you want to replace it. We recommend saving the old file to be able to restore it.
The information for where the Control Bars are located for a chart are saved with the Chartbook.
