Date/Time: Tue, 26 Nov 2024 08:47:21 +0000
Sell one contract & Buy another contract
View Count: 254
[2023-12-08 16:01:47] |
User303857 - Posts: 74 |
Hello Support Do you know of a study that with one click Sell one contract & Buy another contract For example: Sell 1 ES and buy 5 ES micros Would some type of spread order entry work for this? Thank You |
[2023-12-08 19:07:33] |
John - SC Support - Posts: 36286 |
You can not do this in Sierra Chart with a single trading account. You would have to have 2 different accounts to do this. Refer to the following: Overview of Trading: Maintaining Long and Short Position for Same Symbol For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2023-12-08 20:44:46] |
Thanks John, I knew that for the same contract , but it is not possible even with the micros? So the MICRO contracts are considered the same symbol as the MINI contracts? Thanks Again ! |
[2023-12-08 21:31:41] |
Sorry - we did not understand that from your original message. The only built-in option for this would be the "Spread Order Entry". Refer to the following: Spread Order Entry Study Otherwise, you would need to put together a custom study to do what you want. But yes - it can be done. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
