Date/Time: Tue, 26 Nov 2024 09:00:09 +0000
Adding to, or changing, the colors in the #1 - #8 Color Palette
View Count: 418
[2023-12-08 09:58:10] |
User92573 - Posts: 530 |
Dear Support Is there any way to adjust, update or even increase the number of colors available in the #1 - #8 Color Palette. It would be really helpful if we could select our own colour ref for the palette. Many thanks. |
[2023-12-08 12:23:46] |
DFromeaux - Posts: 10 |
Hi, If you're referring to the quick color change of drawing tools, these are the customizable colors found on the second customization line of the color palette visible when you change the color of a subgraph. Simply customize these colors to transform the quick-access colors from #1 to #8. To do this, click on the corresponding box, choose the color and click on Add Custom Color. Take a look at the attached image. Have a nice day. |
custom-color-palette.png / V - Attached On 2023-12-08 12:21:18 UTC - Size: 46.88 KB - 102 views |
[2023-12-08 15:40:21] |
John - SC Support - Posts: 36286 |
The documentation on this is here: Graphics Settings: Setting Default Custom Colors For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
