Date/Time: Tue, 26 Nov 2024 08:57:46 +0000
How do I put more space between
View Count: 213
[2023-12-07 20:56:45]
User740504 - Posts: 110
I am trying to customize the Chart Trade Menu that is shown when right clicking on a chart.
I am trying to put in a large amount of space between different groups, to separate the distance the mouse has to move to avoid accidentally clicking the wrong menu item. Adding multiple separator tabs/lines does not do this, and any duplicate separator lines are automatically removed upon saving and re-entering the Customize Chart Trade Menu window.
I currently use hotkeys for most of this, but am trying to build in redundancy in case the keyboard goes out.
Currently I am putting in a lot of garbage values (menu items that I never use) to create space between the items I need to use. I'm just curious if there's a way to add more space between the selection items so I don't have to buffer it with other order types to create a visual contrast.
Thank you.
Edit: I have attached an image of the Chart Trade window with the main items I use highlighted in orange. The rest of the text is used as filler to be able to separate the items I only care about using. I'm trying to see if I can get rid of this filler and just have open space.
Date Time Of Last Edit: 2023-12-07 21:08:34
imagechart trade menu.png / V - Attached On 2023-12-07 21:03:20 UTC - Size: 50.4 KB - 74 views
[2023-12-07 22:10:59]
John - SC Support - Posts: 36286
There is not another option. The single separator is the only thing we have. What you are doing is the best option we can think of.
[2023-12-07 23:09:07]
Good to know, thanks John.
