Date/Time: Fri, 26 Apr 2024 01:06:02 +0000
15 min 20 EMA in a 5 min chart
View Count: 2942
[2013-05-05 12:02:46] |
User25261 - Posts: 24 |
hi, how i can put a 20 EMA from a 15 minut chart in a 5 minut chart? i want to have this 20 EMA from the 15 min chart in the 5 min chart,it like i want to copy it in the 5 min chart. thanks |
[2013-05-05 19:34:29] |
Tonkadad - Posts: 235 |
Try a 60 EMA on the 5.
[2013-05-05 22:08:33] |
M5amhan - Posts: 468 |
use the study/price overlay study on your 5min chart you will have to open a 15min chart and add a 20ema to it first |
[2013-05-05 22:13:20] |
Refer to this help topic: Http://www.sierrachart.com/index.php?l=doc/helpdetails28.html Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
