Date/Time: Tue, 26 Nov 2024 08:42:30 +0000
Highlight Number bars calculated value according to bar
View Count: 352
[2023-12-07 19:24:15]
iamLL - Posts: 4
I've trying to highlight my Delta (Ask vol bid vol difference) according to the number and the bar, but I can't find how to do so.
The idea was to be able to quickly identify divergence by doing so:
1) Delta is <-50
2) but Bar is green (closing higher than open)
or
1) Delta is >50
2) but Bar is red
Is this possible with this study? Should I use another one?
Is it also possible to display this same number above the candle according to the same conditions?
I also would like to know if we can display value area for individual bars in Numbers Bars mode? POC is available but I can't find Value Area.
Thanks in advance for your help.
Date Time Of Last Edit: 2023-12-07 19:25:22
[2023-12-07 21:54:44]
John - SC Support - Posts: 36286
You need to use the "Volume at Price Threshold Alert V2" to get the first part (Delta is > < 50). You will then combine that with whether it is an Up bar or down bar (which you will need to do by checking whether Close is greater than or less than the open). Refer to the following:
To get a highlight of some kind, you will want to use the "Color Bar Based on Alert Condition" study. Refer to the information at the following link:
To display a value above/below a bar use the "Study Subgraph Above/Below Bar as Text" study:
To display the Value Area for individual bars, you would have to use the "Volume by Price" study and set the following Inputs:
- Draw Mode: POC, VAH, VAL Lines Only
- Volume Graph Period Type: Multiple Profiles Based on Bar Count
- Number of Bars for 'Based on Bar Count': 1
[2023-12-08 09:22:16]
iamLL - Posts: 4
Perfect, thank you for your answers, i'm gonna work on that!
