Date/Time: Tue, 26 Nov 2024 11:57:15 +0000
wrong colors for candle
View Count: 184
[2023-12-07 15:38:37] |
User585993 - Posts: 83 |
How can I change the settings of an up-and-down bar? I'd like to have green bars only when they are Up compare to the previous bar and vice-versa
Date Time Of Last Edit: 2023-12-07 15:40:55
Screenshot 2023-12-07 093007.png / V - Attached On 2023-12-07 15:36:46 UTC - Size: 90.97 KB - 62 views |
[2023-12-07 17:04:06] |
John - SC Support - Posts: 36286 |
Refer to the following: Graphics Settings: Up/Down Coloring for OHLC Bars Based on Previous and Current Close (Global Settings >> Graphics Settings >> Other) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
