Date/Time: Tue, 26 Nov 2024 08:56:33 +0000
Alert Manager Disable 'Always on Top' feature?
View Count: 253
[2023-12-07 15:24:20]
User14953 - Posts: 236
How to disable the Always on Top feature of the Alert Manager?
Then it's possible to tuck the unchanging static portion of the Alert Manager window under the chart so as not to block that important information.
imagesierra alert mgr spacehg.png / V - Attached On 2023-12-07 15:23:09 UTC - Size: 19.36 KB - 75 views
[2023-12-07 16:47:45]
John - SC Support - Posts: 36286
Under the "File" menu is the option for "Always on Top". Make sure there is not a checkmark next to this and it will not be on top. Refer to the following:
Alerts Manager: File >> Always on Top
[2023-12-07 23:22:10]
Under the Sierrachart window; How to tuck the unchanging static portion of the Alert Manager window under the Sierrachart window so as not to block that important information.
[2023-12-08 15:28:44]
If we are understanding what you are asking - you set the Alert Manager so that "Always on Top" is not enabled, then put it where you want it relative to the main window and click on the main window to bring it above the Alert Manager.
