Date/Time: Tue, 18 Feb 2025 22:34:37 +0000
Horizontal Line from Spreadsheet
View Count: 379
[2023-12-07 15:12:26] |
pismo10 - Posts: 161 |
How can I draw a horizontal line on an price chart from a cell that is calculated in a spreadsheet.scss. Thanks |
[2023-12-07 16:46:20] |
John - SC Support - Posts: 38029 |
You can not do this from a "standard" spreadsheet (i.e. a spreadsheet opened using File >> New/Open Spreadsheet). You need to use the Spreadsheet Study and then enter the value you want in row 3 of the one of the Formula Columns (such as column K) and this will create the line. Refer to the following: Using the Spreadsheet Study For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2023-12-07 18:14:46] |
User584084 - Posts: 266 |
Google Sheets CSV Importer | SierraChart Custom C++ Study https://www.youtube.com/watch?v=0R73EQxfeGY Date Time Of Last Edit: 2023-12-07 18:15:47
[2023-12-07 20:13:59] |
Be great if I could find a password it will accept..
[2023-12-07 22:37:24] |
1) In Google Sheets, go to File >> "Make a copy" of the password protected sheet. A Copy Document window pops up. Type a name for the file, Folder >> My Drive and click the "Make a copy" button. 2) Click the "Share" button in the upper right hand corner of your new Google Sheet. Under General Access, change access from "Restricted" to "Anyone with the link" and click Done. 3) Change the ES price levels in the new Google sheet to match current price levels. 3) Now copy the URL to the Google Sheets Importer Study in Sierra Chart. Should work now. Date Time Of Last Edit: 2023-12-07 22:39:34
