Date/Time: Tue, 26 Nov 2024 11:44:59 +0000
[Programming Help] - Position confirmation on ACSIL
View Count: 254
[2023-12-06 19:45:03] |
User785723 - Posts: 57 |
I have an ACSIL code which takes positions based on a strategy. I want to wait for the user confirmation to enter the trades, i.e., whenever there is an entry signal, it shows a message on the UI and if the user confirms, taking the position. Is there a way to do this? Date Time Of Last Edit: 2023-12-07 04:48:00
[2023-12-07 04:20:33] |
Flipper_2 - Posts: 57 |
You shouldn't use a pop up box as per, ACSIL Programming Concepts: Use of Dialog Windows in Advanced Custom Studies But you could use a control bar button, Advanced Custom Study Interaction With Menus, Control Bar Buttons, Pointer Events: Advanced Custom Study Buttons and Pointer Events |
[2023-12-07 05:14:26] |
Sierra_Chart Engineering - Posts: 17179 |
Yes you definitely cannot have any type of window that would interrupt the processing of the custom study.
