Date/Time: Wed, 27 Nov 2024 04:52:42 +0000
disable sim/live trade
View Count: 1420
[2014-07-27 15:34:37]
User021827 - Posts: 174
If I have 6 chartbooks open, and want to trade one of them live, but keep the other 5 in sim mode, can this be done ?
Or is the sim mode global and applies to all open books and charts ?
thanks
shane
[2014-07-28 08:19:31]
No, this is not supported. Trade Simulation Mode is a global setting.
However, what you can do is install another copy of Sierra Chart on your system and use a different Trade Simulation Mode setting and share data from the other copy of Sierra Chart. Refer to this page for instructions:
http://www.sierrachart.com/index.php?page=doc/MultipleServices.html
[2014-07-28 13:28:43]
thank you
will check but I have a special version level 3 from broker and I dont think I can do that.
thanks
[2014-07-28 16:08:18]
In this case you will need a direct Sierra Chart account:
https://www.sierrachart.com/index.php?page=doc/doc_DirectAccount.html
