Date/Time: Tue, 26 Nov 2024 11:40:12 +0000
Quick Dom Question
View Count: 230
[2023-12-06 19:10:02] |
dc2uh - Posts: 25 |
When I enter a trade it shows me the amount of ticks. How do i set it so that i see the dollar amount at each tick? For example how do i get it to show me how much money i would be up in 25 ticks Thank you |
[2023-12-06 21:37:44] |
John - SC Support - Posts: 36286 |
Refer to the following: Chart Settings: Profit/Loss Format (List) (Chart >> Chart Settings >> Trading menu) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2023-12-06 23:56:49] |
dc2uh - Posts: 25 |
I clicked on everything on there and it didnt do anything. I have it set to currency but it still only shows me ticks when actually in a position When im in a trade it says 1t 2t 3t etc how do i get it to show 10 20 30 etc Date Time Of Last Edit: 2023-12-07 00:28:53
Screenshot 2023-12-06 182614.png / V - Attached On 2023-12-07 00:27:20 UTC - Size: 15.97 KB - 60 views |
[2023-12-07 16:07:58] |
Sorry, we figured it was the orders you were referring to. What you are viewing is the Profit/Loss column in the DOM. To change the format for that column, you need to click on the header that states "P&L" (or something else if you changed it). Each time you click it steps through each of the possible formats, so you may need to click multiple times to get to what you want. Refer to the following: Chart Trading and the Chart DOM: Chart DOM Position Profit and Loss Column For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
