Date/Time: Tue, 26 Nov 2024 11:41:54 +0000
MES Contract Margin Requirements
View Count: 464
[2023-12-06 16:51:53]
User446764 - Posts: 4
My broker Insignia futures offers day trading margins as low as 50 dollars per MES contract. However, Sierra chart uses the standard margin requirements of 1200 per MES contract. Is It possible to reduce my margin requirements needed to open an MES position on Sierra Chart? Thank you.
[2023-12-06 18:15:44]
John - SC Support - Posts: 36286
Sierra Chart does not do anything with the margins unless you are using our Simulated Futures Trading Service, but then you have control over the margins that are used.
You need to ask your broker about this, as they are the ones that control this.
