Date/Time: Tue, 26 Nov 2024 11:38:12 +0000
Rectangle with just a midline
View Count: 380
[2023-12-06 15:46:11]
User987069 - Posts: 45
When using one of the rectangle tools I notice there's an option for ''No vertical lines'', is there a way to also get the horizontal lines not visible as well and just show the midpoint of a rectangle? Im currently having to draw a horizontal line over the midpoint and then go back and notch the Outline Width down to zero in order to just see a midpoint line without the outer 4 lines.
[2023-12-06 16:42:48]
User719512 - Posts: 264
Try setting the outline color to the color of your chart background. At least I think that's what you are after...
[2023-12-06 17:48:34]
This is actually exactly what I'm looking for... Thanks!
