Date/Time: Tue, 26 Nov 2024 11:43:37 +0000
Auto Vertical Scale setting to include working orders
View Count: 219
[2023-12-06 05:09:33]
toani - Posts: 2
Hi!
I am experiencing an issue with Sierra Chart where I open positions using bracket (OCO) orders in which I am unable to see the orders because they extend beyond the limits of the screen. Most of the time, I manually scale to locate and drag the orders to the desired regions. However, this becomes problematic if, for some reason, I close a position via a new limit order (which happens to be a bracket).
Upon closing the position, it opens new stop-market and target-limit orders. There have been instances where I canceled all of them manually, but one order is still lurking far off the screen. These orders are particularly dangerous because, unlike limit orders that are meant to buy low and sell high, a lurking stop order does the opposite—it buys high and sells low.
To address this issue, all I need is for the vertical scale to adapt automatically to display working orders as they are created, unless it is in manual mode.
Any help would be greatly appreciated.
[2023-12-06 17:50:40]
John - SC Support - Posts: 36286
There is not an option for this.
[2023-12-06 18:08:13]
toani - Posts: 2
Ok Thanks
