Date/Time: Tue, 26 Nov 2024 10:47:34 +0000
Sierra Chart is not found in add or remove programs on my windows laptop
View Count: 184
[2023-12-05 23:32:25] |
pennydoll9 - Posts: 20 |
I installed sierra chart on one of my windows laptops and I don't see the application in add or remove programs, Why is that?
[2023-12-06 08:05:19] |
Sierra_Chart Engineering - Posts: 17179 |
Refer to: Software Download: Uninstalling Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
