Date/Time: Tue, 26 Nov 2024 10:28:13 +0000
ERROR WITH THE CHART SCHEDULE
View Count: 184
[2023-12-05 20:51:28] |
mcv215 - Posts: 8 |
In the CLF24-NYMEX schedule, the start of the day is at 9:30am and it should be at 8:00am, thank you very much
Captura de pantalla (2).png / V - Attached On 2023-12-05 20:49:12 UTC - Size: 120.07 KB - 62 views Attachment Deleted. |
[2023-12-05 21:28:22] |
John - SC Support - Posts: 36286 |
You can change this for your charts by adjusting the Session Times. Refer to the following: Chart Session Times And you can update your Symbol Settings as well to make sure that any new chart has these Session Times set. Refer to the following: Global Symbol Settings: Instructions For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
