Date/Time: Tue, 26 Nov 2024 10:45:37 +0000
IQFeed and Interactive Brokers
View Count: 286
[2023-12-05 19:53:59] |
User951299 - Posts: 1 |
Hi. I was interested in using DTN IQFeed as a real-time market data source within Sierra Chart and Interactive Brokers as the trading service provider. Is this possible? i.e., to have a DOM, for example, being populated with real-time data from IQFeed but set up so that when placing orders on the DOM, those orders are being routed to Interactive Brokers? Thank you.
[2023-12-05 21:25:11] |
John - SC Support - Posts: 36286 |
Unfortunately, this is not supported. There is not a way to get data from one outside source and then trade with another source. It can be done with our Denali Exchange Data Feed, where you are able to get the data from us, and trade with your chosen broker. This is capable since it was part of the original design of Sierra Chart. For more information on this, refer to the following: Real-Time Exchange Data Feeds Available From Sierra Chart: Integration with Trading Services For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
