Date/Time: Tue, 26 Nov 2024 08:41:14 +0000
[User Discussion] - large volume trade indicator
View Count: 298
[2023-12-05 17:32:35] |
User175327 - Posts: 36 |
hi- is there anyway to have the draw mode compare ask and bid relative to each other instead of only having them be compared to all of the visible bids or all of the asks? For instance, if i'm using the automatic Indicator size and my Draw mode is set to "based on total ask bid volume above threshold-difference" if a large bid trades it skews all of the other bid circles. So going forward if a bid and ask order each trade that are the same amount the ask circle is much larger then the equal amount bid circle. Can we make it compare both ask/bid amounts when drawing circle size? I want this to happen in the "visible bars only" setting.
[2023-12-13 15:13:20] |
Hello- SC support, you out there? Looking for an answer> . |
[2023-12-13 16:49:54] |
John - SC Support - Posts: 36286 |
This is not currently supported, and we can not say when we would get to making this change.
