Date/Time: Tue, 26 Nov 2024 08:54:43 +0000
Studies search box?
View Count: 271
[2023-12-05 08:47:20]
User347921 - Posts: 39
Hello, as you know there are hundreds of studies between the standard and users contributed. Is there a search box where we can for example search by keyword, say "Oscillator"? Thanks
[2023-12-05 13:49:19]
Rui S - Posts: 190
If you select any random study name and then type the first letter of the study you are looking for, the window will go to the area where the studies that begin with that letter are located. It makes it easier to look for any study.
[2023-12-05 17:22:49]
John - SC Support - Posts: 36286
The Sierra Chart studies are all listed at the following page:
Technical Studies Reference
You can then search the names on that page.
To search within the documentation you would need to use our Search function or use Google.
[2023-12-13 23:34:13]
User43 - Posts: 101
Hi John,
I still would second the request made by User347921.
I know and use the suggested solutions but find it "cumbersome" finding/selecting the study I've in mind.
You have done such a nice job with the search on settings,
would be great if something similar could be made available to search studies within the chart studies panel.
Just a suggestion, overall I love working with SC and wonder how I could trade before without it.
