Date/Time: Tue, 26 Nov 2024 08:48:41 +0000
No Charts Showing Bars or Data
View Count: 358
[2023-12-05 01:18:50] |
TheProfitStalker - Posts: 4 |
Hello, I just signed up for Sierra Charts late last week and performed all the functions required to get charts. Can you please help me get the charts working. I am looking to trade tomorrow's US Session. Thank you kindly for your help. Will |
[2023-12-05 03:05:32] |
Sierra_Chart Engineering - Posts: 17179 |
Your account has been activated and the usage time extended if necessary. If Sierra Chart is running, it will automatically be activated within about three minutes. However, you may need to exit from the Sierra Chart charting and trading software by selecting "File >> Exit". And then open Sierra Chart through the icon on your desktop or through the desktop Start menu. After your Sierra Chart usage time ends you need to pay for additional usage time through "Help >> Add Usage Credit". To get started with Sierra Chart, follow the Sierra Chart setup instructions here: Sierra Chart Setup Instructions 1 Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2023-12-08 12:40:27] |
Good Morning, When I attempt to log onto the 2nd system I don't get data to both systems and both systems go in and out of connection. What do I do to correct this. I am new to this, so thank you for all your help and patience. Will |
[2023-12-08 15:30:03] |
We see you are using CQG. Who is your futures broker? You cannot use CQG on two systems at a time but you can use Teton order routing on two systems at the same time: Sierra Chart Teton Futures Order Routing However, even in the case of Teton order routing there is a requirement to pay 2 exchange fees for market data on two systems at the same time. Refer to: Denali Exchange Data Feed: Connections However, you can have real-time data on one system and delayed data on another system and pay a single exchange fee. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2023-12-08 15:30:39
[2023-12-08 20:06:54] |
AMP is my futures broker. Please forgive me not knowing. I paid for the Denali feed & have CQG as routing only through AMP. Can you use 2 systems doing this?
[2023-12-08 21:29:49] |
John - SC Support - Posts: 36286 |
No - you can not have 2 systems connecting to the same CQG account. Additionally, if you want to get the Denali data to two different computers at the same time, then you need to pay the exchange fee twice. Refer to the information here: Denali Exchange Data Feed: Denali Exchange Data Feed on Two Computers Simultaneously For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2023-12-12 00:55:39] |
Good Evening, Can you verify I have paid the Denali exchange fee twice and can now be on two different computers with the Denali Data? Thank you for all your help...Just trying to get everything right. Thank you, |
[2023-12-12 15:39:39] |
You do have the Denali Exchange Data Feed setup for 2 systems, so you can get the Denali data to two different computers at the same time. But, you can not have two different connections to CQG at the same time. Therefore, if you want to get the data to two different computers running Sierra Chart at the same time, one of those installations will have to be connected to "SC Data - All Services" and use the symbols for that service, when the other computer is connected to CQG. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
