Date/Time: Tue, 26 Nov 2024 10:35:35 +0000
Futures Data is Delayed and I don not why?!
View Count: 301
[2023-12-04 22:33:12] |
Ragy - Posts: 29 |
Hello I have Teton and live count at AMP and I connect to Teton at least one every month to keep my denlai futures data. I am using SC Data mainly to show NASDAQ Total View for Stocks and Future data. But today after market closed the data was delayed. Could you please check my account and see if I am missing on steps? Thanks! |
ES Chart Showing Delayed.PNG / V - Attached On 2023-12-04 22:33:01 UTC - Size: 60.72 KB - 69 views |
[2023-12-05 16:27:10] |
John - SC Support - Posts: 36286 |
Everything on your account looks fine. You state that this was "after market closed", in which case, if this was during the 1 hour break from 16:00 - 17:00 (Central US Time), then seeing a "Delayed" notation is normal, as there is no new data coming in. The check for the delay is by checking the timestamp of the data against the computer time. If the last data was at 16:00 and it is now 16:29:17, you will see a delay of 29:17. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
