Date/Time: Tue, 26 Nov 2024 10:47:39 +0000
[User Discussion] - Trying to get a study to have blue text
View Count: 341
[2023-12-04 20:17:18] |
User749595 - Posts: 17 |
How can I use the custom color feature to create baby blue text for a study that displays text? Seems silly but I cannot seem to find the right color combination. Can anyone help?
[2023-12-04 22:56:38] |
User719512 - Posts: 264 |
Need more context. Is this for a study you are developing?
[2023-12-04 22:58:47] |
I am using the Volume By Price study and want the Volume Numbers Text to be blue.
Date Time Of Last Edit: 2023-12-04 23:05:31
[2023-12-05 00:03:04] |
That's the color of SG7 in Subgraphs.
[2023-12-05 00:13:05] |
Yes, I know - I am trying to figure out what the custom color settings are for blue: Hue, Sat, Lum, Red, Green, Blue combination for just a regular blue. I keep getting a deep purple or something too light.
[2023-12-05 00:22:47] |
1) select the text color 2) select a default color or 3) select a custom color slot 3.5) select a color using the 2 sliders or enter a RGB value 4) Add If you want to see the RGB codes for a default color, select it and the lower right will show the values maybe try Red 0, Green 128, Blue 255 See attachment. Date Time Of Last Edit: 2023-12-05 00:23:56
Screenshot 2023-12-04 161729.png / V - Attached On 2023-12-05 00:22:02 UTC - Size: 211.1 KB - 71 views |
[2023-12-05 02:20:07] |
Yep, I know where to go to select custom colors. My custom color palate does not show blue, it only shows deep purple where your blue is in your screenshot. Can you click on the blue color that is on the top row and 6th in from the left and share a screenshot please? Thanks for your help.
Date Time Of Last Edit: 2023-12-05 02:23:42
[2023-12-05 03:04:25] |
That top row, 6th from left is Red 0, Green 128, Blue 255 (hue/sat/lum of 140 240 120) unsure why you see different colors since my understanding is you can't change the "Basic Colors" in that top grid of colors. |
