Date/Time: Tue, 26 Nov 2024 10:54:37 +0000
Color Based On Alert Condition
View Count: 217
[2023-12-04 18:13:08] |
User585993 - Posts: 83 |
I have "Draw Extension Lines at Color Value= Extend to Future Bar Close Crossing", but it's not working, how can I fix it? As you can see in my chart I have vertical lines but I need to change them to "Extend to Future Bar Close Crossing" Date Time Of Last Edit: 2023-12-04 18:17:10
Chartbook1.Cht - Attached On 2023-12-04 18:11:15 UTC - Size: 9.95 KB - 218 views |
[2023-12-04 18:32:10] |
John - SC Support - Posts: 36286 |
Keep in mind, the extension lines are displayed at the Price Level when the condition is true. In your case, you have the "Output When Condition Ture" set to "1.0". Therefore, the extension lines are being displayed at a price value of 1.0, where you can not see them. You need to set up the Color Bar Based on Alert Condition for the "Output When Condition True" to be at the price level you want. You may have to create another study to get that price level, and then use the option for "Study Subgraph Reference" to get the level you want. Refer to the following section: Color Bar Based on Alert Condition: Output When Condition Is True For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
