Date/Time: Tue, 26 Nov 2024 10:52:51 +0000
Replay dont work
View Count: 265
[2023-12-04 16:44:43] |
kevin crochon - Posts: 2 |
Hi, why i can't backtest with my footprint please, when i choose a date for replay my footprint still blocked , thanks
[2023-12-04 17:59:48] |
John - SC Support - Posts: 36286 |
What do you mean "my footprint still blocked"? Typically if there is an issue with a replay when setting a starting date, the issue is that the data is not loaded back to that date, so the replay has a problem immediately. Make sure you have data displayed in the chart going back to the point in time from which you want to start the replay. Refer to the following: Replaying Charts: Replaying Chart from Specific Date-Time For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2023-12-05 00:36:14] |
my footprint (chart) can only go as far as October 05 in backtestingmy footprint (chart) can only go as far as October 05 in backtesting
[2023-12-05 16:29:47] |
We are not sure what you are trying to tell us with your last post. If you are trying to get data further back than October 5, then you will need to use a Continuous Futures Contract Chart. Refer to the following: Continuous Futures Contract Charts For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
