Date/Time: Tue, 26 Nov 2024 11:29:08 +0000
NO LIVE US STOCK DATA
View Count: 245
[2023-12-04 15:07:41] |
User452635 - Posts: 45 |
Dear Sir/Madam I'm not getting Real time US Stock Data. Payment has already been made, but I always get the message that Denali exchange Data has been cancelled due to insufficient funds. Can you please look into this issue ASAP. I'll greatly appreciate your help. Robin. |
[2023-12-04 15:15:29] |
Sierra_Chart Engineering - Posts: 17179 |
Tell us one of the symbols you are using. You should be getting real-time data for -NQTV symbols. You may also need to restart Sierra Chart. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2023-12-04 15:23:41] |
Dear Sir/Madam The Live US Stock Data is on now. Thank you so much. I appreciate your quick response. thanks robin. |
