Date/Time: Mon, 21 Apr 2025 18:07:47 +0000
Changing ticksize for VbP for TPO study independently
View Count: 408
[2023-12-04 14:31:36] |
Wernitschanton - Posts: 34 |
Hey team. It would be really helpful if you could change the ticksize for the TPO volume by price study without automatically changing the size of the TPO. Best Tony |
[2023-12-04 17:23:30] |
John - SC Support - Posts: 39380 |
When a Volume by Price study is associated with a TPO study, then the "Ticks per Volume Bar" is controlled by the TPO study and can not be set differently. You can create a Volume by Price study that is independent from the TPO and displays on the right side of the chart that has a different "Ticks per Volume Bar". Refer to the following: Volume By Price Study: Set as Independent Volume Profile for TPO Chart For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2025-02-18 19:58:24] |
XL - Posts: 17 |
@John, when following your method, it does what you said; now in this example, the VbP profile which I set as Delta Bars that overlap the volume profile, is there a way to adjust the Ticks Per Volume Bar & have them overlap the VbP volume profile?
[2025-02-18 23:00:00] |
We are not understanding the question.
