Date/Time: Mon, 16 Sep 2024 19:15:23 +0000
Iqfeed Question
View Count: 269
[2023-12-04 04:20:06] |
User417302 - Posts: 67 |
I have some data needs that Sierra doesn’t support. As such I’m looking at iqfeed to meet my data requirements that Sierra doesn’t support. I have 2 questions: 1) which service pack would I need, currently I have service pack 10 2) can I run iqfeed in another instance of Sierra without using support for Denali? I want to use this instance for a pure iqfeed connection and use another instance of Sierra for Denali data only. Thanks, |
[2023-12-04 04:24:15] |
Sierra_Chart Engineering - Posts: 16387 |
1. Yes you would need service package 10 or higher. 2. Yes this is correct. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2023-12-04 04:30:45] |
Ok great, thank you for the quick response.
